Home > Forums > Software User Forums > Fidelity CFD
Parallel Processing of unsteady, structured single block c-grid
Old   April 22, 2010, 11:15
Default Parallel Processing of unsteady, structured single block c-grid
Daniel
drrbradford is on a distinguished road
I have a single block structured mesh built over a very simple 2D rocket shape (hemisphere nose-cone-cylinder). I am investigating oscillation of shockwave position at transonic speeds so must run an unsteady simulation.
I have access to a cluster of PCs which couples eight processors together. I intended to run the simulation on this cluster as it would take ~4weeks on a single processor. Is it possible? If so, how do I implement it?
Daniel
drrbradford is offline   Reply With Quote
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
parallel processing and dynamic mesh Anand FLUENT 0 January 9, 2009 15:52
structured grid and/or increase convergence rate Ashish Pande FLUENT 0 May 12, 2006 03:36
Grid generator for structured grids Tore Myhrvold Main CFD Forum 5 January 21, 1999 08:09
