Home > Forums > Software User Forums > Fidelity CFD
Can CFview reads CGNS ?
Like Tree4Likes
  • 1 Post By Aji
  • 1 Post By Stephan
  • 1 Post By afeng0796
  • 1 Post By sanboju
Old   May 23, 2008, 05:14
Default Can CFview reads CGNS ?
Vinayender
Hi all,
Can CFview reads CGNS file that contains grid and solution data ?
Thanks, Vinayender.
Old   June 4, 2008, 03:55
Default Re: Can CFview reads CGNS ?
Eddy
Maybe can't
Old   June 6, 2008, 03:40
Vinayender
Thanks Eddy for your response.
Recently I found that CFView can read CGNS File if the geometry is written in x,y,z coordinates. But it is not reading if the geometry is written in cylindrical coordinates.. Can any one help me out in this regard.
Thanks, Vinayender.
Old   July 15, 2008, 13:19
Aji
Dear Vinayender,
Could you use Plot3D format? CFView can read this format.
Regards,
AJi
vinayender likes this.
Old   July 18, 2008, 02:43
Stephan
Dear Vinayender,
Generally CFView is supporting 2D and 3D structured multi-block and unstructured CGNS data sets. May you know - CGNS is a general purpose format for CFD data storage and cross system compatibility.
As far I could see, there are some information included also in the CFView manual, but maybe not specific anbough for your question. Numeca is refering to http://www.cgns.org for a complete presentation of the format.
May this will help? Regards,
Stephan
Old   July 23, 2008, 08:14
Vinayender
Dear Aji,
Thank you very much for your replay. Will it also support if I write the Grid in Cylindrical coordinates ?
Thanks, Vinayender.
Old   July 23, 2008, 08:16
Vinayender
Dear Aji,
Thanks, Vinayender.
Old   July 23, 2008, 08:17
Vinayender
Dear Stephan,
Thank you very much for your replay. I would certainly refer to them.
Thanks, Vinayender.
Old   July 21, 2009, 05:25
deng qingfeng
afeng0796 is on a distinguished road
The Tecplot or tec360 will help,and it supports CGNS format
afeng0796 is offline   Reply With Quote
Old   November 27, 2009, 11:50
Default Thank you all
Vinayender
vinayender is on a distinguished road
Thank you all for your replays !!
My porblem got resolved
Thanks ,
Vinayender
vinayender is offline   Reply With Quote
Old   March 17, 2011, 07:57
mistry
csmistry is on a distinguished road
Dear Vinayender,
My company is planning to purchase CFD software and for that CFX,StarCD and Numeca we bhave option out of which we want to compare their results with same mesh and boundary conditions can you suggest something how to insert CFX mesh to Numeca?
thanks
csmistry is offline   Reply With Quote
Old   May 10, 2011, 07:32
Lightbulb Numeca mesh
  #12
sanboju
sanboju is on a distinguished road
Try to use hypermesh to convert any CFD file in a Numeca file, and viceversa. I used that program to mesh some structures for Abaqus FEM, Nastran and Ansys but I've just read about the possibility of mesh the environment like any CFD.
If you try to use Numeca IGG environment you'll see that mesh code is very comfortable and the smothing surface option makes a better mesh with a better flow transfer between cells
cheers,
Sanboju
sanboju is offline   Reply With Quote
Can CFview read CGNS file ? Vinayender Main CFD Forum 0 May 23, 2008 05:28
CFView run on the Suse10.2 system has an erro exergy Fidelity CFD 2 September 26, 2007 05:36
CFView run on the suse10.2 has an erro exergy Fidelity CFD 0 August 18, 2007 22:42
cfview in cascade fishcuter Fidelity CFD 0 February 29, 2004 02:35
cfview fishcuter Fidelity CFD 0 February 29, 2004 02:34
