Home > Forums > Software User Forums > Fidelity CFD
Blade Optimization
Old   June 15, 2011, 08:36
Default Blade Optimization
diya
jepit is on a distinguished road
anyone can help me, how to do this?
jepit is offline   Reply With Quote
Old   June 15, 2011, 21:28
CJ
oldshoes81 is on a distinguished road
Send a message via MSN to oldshoes81 Send a message via Skype™ to oldshoes81
Hi Jepit,
Your question is too broad. It would take more than hundreds pages of this forum to explain to you how it is done.
In addition, for your information, you would need a geometry represented as parametric in which in FINE/Design3D suite, you could so everything from sketching the blade to optimization. Here below explain the flow chart:
IF YOU HAVE YOU OWN GEOMETRY:
1. Import the geom (assume the geom is clean) in autogrid to export as native format, the .geomturbo.
2. Perform 'Fitting' process in FINE/Design3D and convert into parametric. Adjust the up-bound and lower-bound according to suit your optimization purpose.
3. Running the 'screenning' process as initial result.
4. Generate the database.
5. Running the 'optimization' module.
IF YOU DO NOT HAVE THE GEOMTRY:
1. Start sketching using AutoBlade.
2. Continue with step 3, 4 and 5 above.
I hope this help.
Regards
CJ
NUMIT Enterprise, Malaysia
+6 017 656 3436
http://maccom-numit.blogspot.com
http://www.numit.com.my
Email : seiko.q@numit.com.my
oldshoes81 is offline   Reply With Quote
Rotating blade in circular/square vessel (Salome+OpenFoam) voingiappone OpenFOAM 0 May 19, 2011 11:38
Blade tip with tetra/prism method vinc ANSYS Meshing & Geometry 0 May 17, 2011 15:22
blade to blade 2D CFD Hina Main CFD Forum 0 December 30, 2010 09:14
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 17:06
Meshing a 3D, tapered and twisted blade with Gambit-TGrid teskio ANSYS Meshing & Geometry 0 July 3, 2009 10:36
