Home > Forums > Software User Forums > Fidelity CFD
which turbulence model is fit for low speed axial compressor?
Old   July 19, 2011, 11:24
Smile which turbulence model is fit for low speed axial compressor?
ski
sukiska is on a distinguished road
hello,I am trying some k-e models in the numeca for a low speed compressor. the maxium axial velocity is 30 m/s .
I used the SA model in the past and the calculated total characteristic line has a good agreement of the test result, but the parameters distribution at the outlet section does not.
So I decided to use some k-e models yet I find that it will blow up at a bigger flow rate than SA model using k-e models or SST model of numeca. I set the total temper and pressure as inlet condition and static pressure as the outlet condition, CFL=3, the y plus <8. I do not know the reason of blow up at bigger flow rate using k-e model ,or is there some operation should be done ?
Thank you very much for your help!
sukiska is offline   Reply With Quote
Old   July 20, 2011, 09:58
Arslan
ArslanOZCAN is on a distinguished road
Hi;
Try to keep y+ value in 1-5 range and try k-epsilon (extended wall function) turbulence model. You should first try it in the design pressure, than you can try the other presures to plot the eprformance map.
ArslanOZCAN is offline   Reply With Quote
compressor, numeca, turbulence model
Turbulence model for flow over a cylinder at Re=10000 ojha.mayank485 CFX 18 June 24, 2018 19:01
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
Turbulence Model for Rectangular Duct Flow ken FLUENT 4 May 26, 2005 20:39
Turbulence model in flow driven by surface tension Z. ZENG Main CFD Forum 7 April 28, 1999 07:18
