Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
SOLIDWORK FLOW SIMULATION 2011 help
Old   October 26, 2012, 02:29
Default SOLIDWORK FLOW SIMULATION 2011 help
nick
mangotango is on a distinguished road
Good Morning,
I am a Mechanical Engineering student and very new to this software. I would like to know if its possible to add a rotation flow to a object with its center point outside of the computation domain. Your help will be appreciated.
mangotango is offline   Reply With Quote
Old   November 2, 2012, 22:39
Scott Vader
Vader is on a distinguished road
Hi MT
Just tried it. No, it doesn't work. Throws an error during meshing.
regards
Scott Vader
Vader is offline   Reply With Quote
Old   November 5, 2012, 02:12
Disabled
Boris_M will become famous soon enough
I would say if you could explain what you want to do, it would be much easier to tell if the way you want to use the software makes sense. There are some ways to do that and the answer it doesn't work does not tell which way does not work nor does it indicate if this is even the way to do it for your application.
So please explain what your application is and why is there a rotating flow and why is the center out of the computational domain.
Boris
Boris_M is offline   Reply With Quote
flow simulation
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Channel flow setup in Large-eddy simulation Weihua Main CFD Forum 6 November 17, 2015 09:33
Problem, solidworks flow simulation castaway FloEFD, FloWorks & FloTHERM 3 September 11, 2012 12:44
About unsteady flow simulation Ji Fidelity CFD 3 June 10, 2003 10:04
2D Flow Simulation Sethu Raghavan Main CFD Forum 0 October 18, 2001 01:12
