Modeling component of system level in Flotherm |
April 23, 2014, 03:56 |
SOHYEON MUN
Rep Power: 12 |
Hi. guys.
I am employed in relating to RRH(Radio Remote Head) and design mechanism and thermal structure from component to closure structure by using Flotherm. I was just wondering how to design component level such as FPGA, Flash memory for other company. There is no difference between 2R model and detailed model as i know. Of course, If you use detailed modeling, the result is more accurate. however It takes a long time for data to calculate due to number of grids. How do you design component or PCB at system level ? |
April 30, 2014, 03:55 |
Gabriel Ciobanu
there are definitely differences in results between detailed modeling and the simple 2R components (differences that obviously are more visible with more power applied). When performing PCB simulations (70% of my work time) I have one basic rule that I follow: the level of details in the model must be of the same magnitude in the entire system. For example: A detailed component (I make components with flopack and then run several simulations on JEDEC environments to match Rth’s form the datasheet to the model) should be associated with a detailed PCB (each layers modeled individually with copper patches, thermal vias…etc) and a detailed enclosure (shape and volume). On the other hand, a big system with coolers, heatsinks, displays, several PCBs can be modeled with 2R compact components, averaged PCB orthotropic thermal conductivity…etc. Best regards, Gabriel |
Fluent Vs Solid-works Flow Simulation | Mortezab | Main CFD Forum | 16 | July 5, 2013 02:47 |
Transient Modeling in Flotherm | bighead | FloEFD, FloWorks & FloTHERM | 11 | May 21, 2013 12:47 |
Flotherm, Purpose of compact component | ABHIRAM | FloEFD, FloWorks & FloTHERM | 1 | June 1, 2012 07:13 |
Flotherm-Icepak comparison for electronic cooling | Masoud Ameli | FLUENT | 0 | February 28, 2005 09:00 |
Level Set in Cavitation Modeling | Niklas Wikstrom | Main CFD Forum | 1 | September 9, 1999 13:08 |
