Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Heat Source (Forced Air Cooling)
Old   July 6, 2014, 23:15
Default Heat Source (Forced Air Cooling)
will321321 is on a distinguished road
Hello Gentlemen,
I am trying to simulate the cooling down of a certain material through force air cooling.
My question is if say I put that certain material in front of a fan and define it as a heat source say 80KW will that material's heat slowly cool down? or will it stay at a constant 80KW.
By the way im using FloEFD.
Thank You in advance for the Help.
will321321 is offline   Reply With Quote
Old   July 8, 2014, 05:55
Disabled
Boris_M will become famous soon enough
Hi Will,
If you apply a heat source to the material with 80kW then the 80kW are constant through out the simulation and the temperature will converge accoring to the cooling due to the fan.
If the initial condition in the project is lets say 20°C then the material will heat up to the steady state. If you want to do a transient simulation in order to see how long it takes to reach maximum temperature then you can do that too. In general the solver will iterate to the steady state solution in this case as there is no change over time both will reach the same temperature.
In a steady state simulation you will see the temperature reaching maximum over a certain number of iteration but doesn't give you a time that it took to reach it. This is what you can do in a transient simulation.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
Old   July 8, 2014, 07:11
Hi Boris,
Well explained as always, that input clarified a lot of things to me on how heat source works. Now I have a clearer concept on my simulation.
Thank you so much and God Bless You.
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
