November 5, 2014, 08:07 |
FloEFD results file structure
Rep Power: 11 |
It is possible to export the results (ex: velocity) from Solidworks. Unfortunaly, exporting results is not available from the API. Is there a way to retrieve the results directly from the result files (.FLD) ? Is there any white paper regarding the file structure? Thank you for any comments. Regards, |
November 5, 2014, 17:12 |
Disabled
Rep Power: 23 |
Hi raptor,
what do you need the export for? Maybe there is a way to do it depening on what you want to do with it. Boris |
November 5, 2014, 19:06 |
Rep Power: 11 |
Hi Boris,
Thank you for your reply. I know it is possible to retrieve a result at a defined point with API. However, it is really time consuming to retrieve all cells. So, I would like a way to get the results for the entire domain more efficiently. And exporting to excel/ascii is not possible from the API. I would like to display my results with VTK (Visualization Toolkit) in C++ to have advanced features. For example, to display a range of velocities isosurfaces (10 to 30m/s for example). Loading the result directly from the file would be really more efficient. Regards, |
November 6, 2014, 14:35 |
Disabled
Rep Power: 23 |
Hi raptor,
You can output the results in an XML file and with a little programming you would be able to output all values in a specified format into a file. You can ask for the value and store it the way you want it in an ASCII file. I haven't used it for such a purpose but it should work. Boris |
November 14, 2014, 10:12 |
Disabled
Rep Power: 23 |
Hi raptor,
One thing I'd like to add to my last post. It is not possible to output the cell center coordinates and then therefore the values for that as the parameters in FloEFD are cell center based. But even with that there would be not really a geometry description of the mesh surface on bodies as the surfaces are not in the output. Boris Last edited by Boris_M; November 14, 2014 at 11:24. |
November 14, 2014, 12:13 |
Rep Power: 11 |
Thanks for comments. I ve finally got a good result. In flow simulation/floefd, the evaluation points are finally not a too bad idea. I ve created a binary file based on the result of those points in the entire domain (cells). In VTK, it is possible to create any display from this data. I still need to evaluate the accuracy compared to flow simulation outputs. It gives more flexibility than the flow API. The API is still poor compared to normal user possibilities; and not only in output features. I had a lot of limitations like fluid selections. |
November 21, 2014, 06:23 |
Disabled
Rep Power: 23 |
Hi Raptor,
The API offers some interfacing but as most of the users are not programming experts their interest in the API is therefore low which makes a full flexible API a lower priority compared to adding new physics and other capabilities. Boris |
November 21, 2014, 09:50 |
Rep Power: 11 |
Hi Boris,
Yes, I can understand that. Regards, |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
