February 3, 2015, 10:26 |
1% convergence criteria with SWFS 2013?
Dan Hofstetter
Rep Power: 14 |
Is there a way I can set goals to achieve 1% convergence using SWFS 2013? I like this feature in 2015, but not all of the computers I use have the latest version. I tried setting an equation goal: "{GG Av Static Pressure}/100" and then set the criterion for that goal = 0.0001 just to see what would happen, but it doesn't really work the way I hoped.
February 9, 2015, 05:24 |
Disabled
Rep Power: 23 |
No, this feature was introduced with the latest version and it cannot be done in older versions. You will have to set it manually as an actual value and not percentage but as the value changes, the values you selected are fix.
The way you tried it with an equation goal will give you the 1% value which over the iterations changes and the goal criteria set to 0.0001 is basically a 0.01% fluctuation you allow of that 1% value. So this is not the same as the new percentage way in 2015. Boris |
question about convergence criteria in Flow Simulation | drdet | FloEFD, FloWorks & FloTHERM | 2 | January 16, 2015 09:36 |
Time step size & convergence absolute criteria | yuitsang | FLUENT | 5 | April 15, 2013 04:27 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
What value shall I set for the Convergence criteria? | steventay | CFX | 7 | May 14, 2010 12:44 |
Convergence Criteria | edwin | FLUENT | 1 | February 14, 2008 19:24 |
