Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Transferred Boundary Condition
Old   July 30, 2015, 07:37
Default Transferred Boundary Condition
Giu_Pel is on a distinguished road
Hi everyone!
I started to use SOLIDWORKS FLOW SIMULATION recently to make some simulation for my job. I wonder how i can pass from a local study to a global study using Transferred Boundary Condition. Specifically, i want to study the flux around some components (like a diffuser) locally and then use the results to make a simulation on a bigger domain. Is it possible to make it using Transferred Boundary Condition? Or it is used only to pass from a global study to a local study?
Giu_Pel is offline   Reply With Quote
Old   August 6, 2015, 02:24
Disabled
Boris_M will become famous soon enough
Hi Giu,
it is only meant to do it the other way around. But one thing you could do is to use a point parameter on the small volume you did your detailed study and extract parameters such as velocity and temperature etc. and use that as a source distribution in a boundary condition by using the dependency of the velocity or the parameter you want to apply it to and select the "F (x y z) - table". You need to set the formatting right of the file but then you can get the small model detailed studies outflow conditions as inlet conditions on that small size "box" for the global simulation.
However, keep in mind that usually the global flow has an influence on the small domain so in reality it would probably different by some degree. So you are creating an error to some extent.
Regards,
Boris
Boris_M is offline   Reply With Quote
Old   August 6, 2015, 03:02
Hi Boris!
Thanks for your advice.
You're very kind
boundary, global, local, solidworks, transferred
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Outflow boundary condition in cartesian grid SIMPLE velocity-pressure coupling ghobold Main CFD Forum 9 September 19, 2015 02:50
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 18:34
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
