Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
phase change
Old   January 2, 2018, 10:00
Default phase change
SUN
sxl_sxl is on a distinguished road
Hello everyone:
floefd16 new features:
Real gases with phase change, like refrigerants, etc.
Help introduce phase transition function is very little, I understand the dissolved gas quality component is dry, but its value range is not between 0 ~ 1.
Also want to know the use of phase change function.
Can anyone provide a tutorial on this feature?
thank you all
sxl_sxl is offline   Reply With Quote
Old   January 8, 2018, 06:55
Disabled
Boris_M will become famous soon enough
Hello Sun,
What CAD version are you using? I need to check if I have a model for that CAD system.
Yes, unfortunately there is little information on the phase change capabilities with real gasses. I myself haven't worked with it yet as there are not that many applications that came across my table since V16.
There is a small trick that was necessary back then when it was still a beta. You should use a small admixture of adding also Air with a mass fraction of 0.0001 or some more to the refrigerant. This makes the solver stable and might be a reason for the crash you have. I don't know if this is still necessary but you can try if that helps.
Two other things help as well.
You should specify only one phase at the inlet so not a transitional condition but either a condition where the refrigerant is either liquid or gas.
The other thing is to keep the initial conditions the same as the conditions at the inlet.
If there is a "hard" phase transition you might need to increase the mass fraction of the ideal gas component some more.
Regards,
Boris
Boris_M is offline   Reply With Quote
Old   January 8, 2018, 07:48
SUN
Hello Boris_M
I am using FloEFD.17.0.Stabdalone
Thank you for your reply, I will continue to try to follow your suggestions, and then feedback.
Thank you
Regards,
SUN
Multiphase solvers and non-isothermal phase change erlend_grotle OpenFOAM 1 September 25, 2021 09:48
Need help regarding phase change models in ansys fluent diggee Fluent Multiphase 0 October 11, 2016 11:35
Change phase phenomena Imane FLUENT 0 May 4, 2016 15:56
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 03:59
How to model the solid-fluid phase change in CFX ohrmond CFX 2 May 26, 2006 06:27
