Oleg
Rep Power: 10 ![]() |
I have converted PCB into the FloTHERM project. This PCB has many components on it, including Xilinx FPGAs (like Kyntex-7, Artix-7). Would somebody explain me what material should I then assign to the Material attribute of such FPGAs? By default, this attribute has been assigned as "Lumped component".
Gabriel Ciobanu
Rep Power: 15 ![]() |
lumped component is the least precise way of modeling <- only usable for finding PCB temperatures, air temperature inside enclosure...etc. You should try to find the Rth's in documentation and create a 2R model at least. This will define the thermal resistance from junction to PCB and J to top of the device. Using this approach you can state how much of the heat goes through the top case and how much into the PCB. Best case will be to have the detailed model (geometry and materials). Best regards, Gabriel |
'Dhinesh_J_G
Rep Power: 0 ![]() |
PCBs are Stacked Laminates, it would be appropriate to model it as Orthotropic material.Refer this Calculator to find out kxy and kz (W/mK) of your PCB.
http://www.akemalhammar.fr/online/cond_pcb.html For Modeling the Xilinx FPGA packages use 2R models (Rjc, Rjb) which is released by Xilinx on this link below. www.xilinx.com/cgi-bin/thermal/thermal.pl Congrats on your modeling.. ![]() |
Display Modes | |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
