Radiation heat transfer post processing(FloEFD) |
May 1, 2018, 01:58 |
Aleksandr
Hi! How to display incident radiative flux from one source to another.For example from lamp to surface?
May 7, 2018, 03:50 |
Disabled
Rep Power: 23 |
Hi Aleksandr,
it is not possible to have a surface plot or surface parameter where you select only the radiation coming from a specific surface/source and hitting this surface. If you used the monte carlo radiation model you can use the ray visualization to see how the rays reach a specific surface or how they bounce starting at one surface ending at another. Boris |
May 7, 2018, 14:17 |
#3 | |
Aleksandr
http://docplayer.ru/49341639-Tehnolo...-division.html Last edited by sam63; May 8, 2018 at 01:16. |
May 8, 2018, 03:42 |
Disabled
Rep Power: 23 |
This model is very simple with just one lamp (or radiation source) and it is probably a user-defined visualization parameter where simply the net radiant flux and the leaving radiant flux was used to calculate the incident radiant flux and then the name was given with "lamp" in it.
There is no such parameter by default and this would only work in general if there is no other radiation in the model. If there are two radiation sources such as two lamps and you would like to know how much radiation is arriving at that surface from only one of the lamps, then this would not be possible in this way as the net and leaving radiation rate considers all radiation and not just from a specific object. Regards, Boris |
radiation flux, radiation modelling |
Conjugate heat transfer with solar radiation | adamt1991 | FLUENT | 0 | December 15, 2016 04:06 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
heat transfer with s2s radiation model in fluent | D. L. | FLUENT | 3 | July 31, 2008 07:40 |
radiation heat transfer in gas turbine burner | jarno | FLUENT | 0 | December 27, 2005 08:59 |
