Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
FloWorks torque bug?
Old   November 8, 2009, 18:41
Default FloWorks torque bug?
PJC
Philip Carter
PJC is on a distinguished road
I'm fiddling with FloWorks 08 applied to aircraft wings. I began by running a model with and without a symmetry plane at Z=0. Surface Parameter output for the 2 cases matches nicely, except under integral parameters the torque values are 2X in the symmetry plane case ('Consider entire model' was selected). This applies to torque, torque of normal force and torque of shear force, all. Suspecting either a bad mesh or bad report generation code I ran two more cases, with simpler wing geometry and finer meshes, with the same pattern. In the final case I used an airfoil with known pitching moment, and to my surprise found that the symmetry plane case gave the correct torque, while the full mesh gave half the correct value (all within specified convergence tolerances).
Is this a known problem? If not (which I find hard to believe) would somebody please verify this behavior or tell me I'm an idiot and why.
Thanks,
Philip
PJC is offline   Reply With Quote
positive and negative torque forces Wei-Haur Lam CFX 0 March 19, 2008 07:45
Torque definition Yali CFX 2 January 7, 2008 03:13
Torque calculation in pumping equipment Kirill Main CFD Forum 0 June 26, 2007 16:59
torque calculations Mechstud CFX 4 June 26, 2007 08:53
about use macro to compute torque in TASCflow lancy CFX 0 June 10, 2003 06:19
