April 12, 2010, 10:15 |
Contours of 2D plotting
Yang Yue
Rep Power: 16 |
Hello fellas,
I have a question about the result plotting in 2D. I've chosen NF value as the contour variable and contour type is colour shaded. The snapshots of the ploted result have white lines indicate the free surface of the fluid (I guess) as showed in the attachments. The blue grids repersent the flow while the red grids are voids. Since the deep blue grids do not have free surface, if the white line shows the free surface, it should be above the blue grids. This doesn't correspond to the plotting results. However, the white line shows a more realistic free surface of the flow in the attachment which modelled a plunging jet. So my question is how this white line been plotted? Which data is used to plot the white line of the free surface in 2D? Cheers! Yang |
April 14, 2010, 09:28 |
#2 | |
michael barkhudarov
Rep Power: 18 |
Yang, the white line is drawn based on the fluid fraction F. It is the contour line of F=0.5 since in the void F=0 and in the fluid bulk it is 1. |
May 5, 2010, 06:50 |
#3 | |
Yang Yue
Rep Power: 16 |
A quick question: Is the free surface plotted in 3D also based on the volume of fraction of the cell? I just feel confused about the NF value and the fraction of fluid. Can I explain this like that the NF value is the flag to lable the surface cell, but the calculated free surface is plotted by fuid fraction? Is that the concept of the volume of fluid method? Thanks a lot! Yang |
May 5, 2010, 11:09 |
michael barkhudarov
Rep Power: 18 |
Yang,
You are right, NF is used for labeling free surface cells, while fluid fraction is used for plotting in 2d and 3d. I am not sure the NF flag is part of every VOF method, but it is certainly useful in FLOW-3D. |
December 22, 2012, 15:04 |
fluid depth
Fatema Zandi Goharrizi
Rep Power: 17 |
Hi friends,
How we could get results in post processor part for fluid depth (e.g. in a free surface modelling) along the geometery? |
Turbo contours Max n Min Values | Sans | CFX | 2 | May 31, 2008 04:22 |
Plotting Contours of Experimental Data | Umm.. | FLUENT | 4 | February 20, 2008 16:27 |
Preconditioning and pressure contours | ganesh | Main CFD Forum | 2 | February 18, 2006 00:02 |
extension for liquid fraction contours | venugopal | FLUENT | 0 | June 11, 2004 01:27 |
