November 21, 2012, 00:10 |
how to model thermal bubble inkjet?
Rep Power: 13 |
HI everyone,
I want to model thermal bubble inkjet. i don't know how to heat the liquids and generate bubble. I have used the model: bubble and phase change,heat transfer, surface tension , viscosity and turbulence. In the boundary condition i use wall ->thermal information->power:5e8, but it doesn't work .Only a small region of liquid near the wall increase temperature and doesn't have any bubble or phase change. The liquid i use is water(CGS unit at 20C) In the phase change, I input the data below: saturation pressure:1e6 saturation temperature:373 latent heat of vapor:2.257e6 gamma:1.4 accomodation coefficient:0.1 vapor specific heat:6.67e6 exponent temperature:1.182e-4 superheat temperature:0 can somebody teach me how to set the accurate model to run thermal bubble inkjet simulation? best reards Tim Last edited by dwtme; November 28, 2012 at 21:24. |
November 27, 2012, 20:14 |
Rep Power: 13 |
by the way, my edition is v9.3!
December 4, 2012, 18:58 |
Jeff Burnham
Rep Power: 17 |
If the water is not warming up, I would suggest checking the thermal property coefficients of the water itself (Fluid 1): liquid specific heat CV1, liquid thermal conductivity CHV1. Also set heat transfer coefficient between wall and fluid HWALL1.
December 12, 2012, 22:05 |
Rep Power: 13 |
Dear JBurnham,
Thanks for your reply. I still have some questions. (1)Do I need to creat a component as a wall or use the boundary condition setting"wall", what is the difference? (2)"The heat transfer coefficient between wall and fluid " means the heat conduction coefficient of wall or fluid? Or does it have other meaning? Thanks, Best regards Tim |
January 7, 2013, 12:33 |
Jeff Burnham
Rep Power: 17 |
You can use either a component or a wall-type boundary, it is up to you. The component may be easier to use. The component-to-fluid heat transfer coefficient is described in the User Manual in some detail, including the ways in which FLOW-3D picks a coefficient if one is not defined.
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Flash Process / Problem with thermal phase change model | Ridley | CFX | 0 | July 21, 2010 07:57 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Thermal radiation model selection and application | Jason | Phoenics | 14 | November 18, 2005 05:21 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
