Home > Forums > Software User Forums > FLOW-3D
time-step <dtmin.
Old   December 2, 2013, 05:14
Default time-step <dtmin.
ouni firas
ounifiras is on a distinguished road
Dear experts
I am trying to simulate a flow of labyrinth weir. I have put the finish-time 20 second. I utlusé the model of turbulence ke, I put The Turbulent mixing length as 7% of the flow depth ho over the spillway. i put minimum time step as the 10th-6 goal stop the simulation at the 5 second and this post APPEAR: time-step <dtmin. I have not found an explanation?
ounifiras is offline   Reply With Quote
Old   December 2, 2013, 11:07
dmilano is on a distinguished road
The simulation is stopping because the time step size (which changes every computational cycle) is dropping below the minimum allowable time step size that you set.
Try looking at the short print data in the solver summary file (hd3out) to see if you can determine why the time step is becoming so small. For most simulations an unexpected small time step is caused by fluid splashing, cells with large aspect ratios, or a setup error (a typo in an input, mismatching boundary and initial conditions, etc.)
dmilano is offline   Reply With Quote
Old   December 2, 2013, 11:51
ouni firas
thanks
do you think if i put the minimum time step 1e-40 may lead to a result
Old   December 2, 2013, 11:58
ouni firas
how can I get the solver summary file (hd3out) ?
Old   December 2, 2013, 12:02
Doing this will likely let the simulation run to completion. However, you will need to be cautious when obtaining a solution in this manner since an unexpected small time step usually indicates a mistake in the setup.
Old   December 2, 2013, 12:05
ouni firas
thank you greatly
It should be accessible from the Diagnostics drop down menu
Old   December 2, 2013, 12:12
ouni firas
thank you greatly
Old   December 2, 2013, 15:11
ouni firas
DEAR dmilano
When i run the same simulation with the model of laminar ; the simulation converge and it give good results ; but when i use the turbulence model K-e with a Turbulent mixing length as 7% of the flow depth ho over the spillway the model does not converge and the simulation stop before the finish time and this post APPEAR: time-step <dtmin. I think the problem is related to the model of turbulence.
Old   December 2, 2013, 16:17
It could definitely be the turbulence model. You can try reducing the turbulent mixing length, using the dynamically computed mixing length, or using the RNG k-e model.
Old   December 2, 2013, 16:29
ouni firas
thank you greatly
Old   December 3, 2013, 03:26
ouni firas
dear dmilano
when i have use minimum step Time as 1e-40 . the simulation stop at 8 second an this message appear
''end of calculation at t= 8.001E+00 cycle = 7189
excessive pressure iteration failures''
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
