June 9, 2016, 10:32 |
free surface indicator
Rep Power: 10 |
I am trying to calculate an Integral over the surface of a casting process using FlowSight. I only want to calculate the free surface, not the one touching the wall. Is there a good way of doing that? Until now I have calculated a variable over pressure (=1 if pressure low enough,. else =0) and multiplied that by the variable of interest. However, this does not always lead to stable results. Additional question: When surface integrals are plotted vs time, the values are not the ones that are shown in the induvidual time frames. Is it possible to recieve correct plots for surfaces? Thank you |
free surface indicator |
how to capture free surface cells? | MichaelVS | FLUENT | 1 | June 10, 2015 02:18 |
Floating dok on waves: free surface divergence | Galchenko | CFX | 3 | September 11, 2014 18:04 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 18:13 |
Equilibrium of a free surface under surface tensio | Ryan | Main CFD Forum | 1 | August 7, 2001 16:14 |
Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 21:03 |
