Problem with Baffle output "sediment flow rate" |
March 7, 2017, 09:38 |
Chris
Rep Power: 11 |
Dear experts,
I am doing some more or less basic investigations and just observed a strange issue: I am modeling a straight channel of 0.5 m width, about 30 m length and a packed sediment bed of about 0.3 m thickness. In the last third of the channel a trench is located (actually, this is the migrating trench experiment of van Rijn). The sediment has a diameter of 160 microns and a density of 2650 kg/s. The first 5 meters of the domain have a fixed bed. The initial condition is shown in Figure one names "T=0". On purpose, I chose parameters yielding massive erosion of the sediment, such that nearly all sediment got eroded after 500 seconds simulation time, see Figure "T=500". Checking the output of the baffles I added at several positions (e.g. 5 meters upstream of the channel end) gives sediment transport rates of about zero. I added Figure "TransportedSedimentMass" to show you the problem: The left column is the time, the right column the cumulated transported sediment mass (!) until the end of the simulation at 500 s. As you can see, following the baffle output, less than 0.2 kg have passed that baffle, although nearly ALL sediment was eroded (the total mass in the domain is about 5'000 kg). Did you experience such problems as well? Do I misinterpret the output? What is wrong over here? Thanks a lot for your help in advance. I very appreciate it! Chris |
March 13, 2017, 00:13 |
Chris
Rep Power: 11 |
Thanks, this information clarifies the issue and helps me quite a lot!
Connecting question: How is the output "mass of packed sediment species x" (x stands for the number of the corresponding species) determined by the software? I am missing some information here to interpret my results. Thanks a lot in advance! Last edited by chripasch; March 13, 2017 at 08:49. |
March 13, 2017, 08:49 |
Chris
Rep Power: 11 |
Thanks a lot in advance! |
flow past abdominal aorta. Complex BC problem. | ziemowitzima | OpenFOAM Running, Solving & CFD | 1 | July 26, 2022 05:12 |
Problem with porous flow at multi-material interface with large permeability diff. | Hisham | OpenFOAM Programming & Development | 1 | June 3, 2016 10:51 |
Newbie to compressible, viscous flow. Advice on approach to problem? | bzz77 | Main CFD Forum | 4 | December 4, 2012 07:59 |
Multiphase flow problem | icedou | FLUENT | 6 | July 10, 2005 02:52 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 08:40 |
