August 3, 2017, 14:34 |
Inlet conditions
Juan
Rep Power: 15 |
Hi
I am simulating a 3D pipe model using k-epsilon turbulence model. Is it possible to define the turbulence at inlet with Turbulence intensity (5%) and Viscosity Ratio (50)(these are the values I have computed according to my conditions) or this combination is only possible for external flows?. I used this one and my solution converged but I am not sure about if this combination is adequate for this case. Is the combination turbulent intensity and hydraulic diameter the only one for internal flows? Thanks |
Inlet boundary conditions for turbulence changing | robboflea | FLUENT | 6 | April 7, 2022 14:37 |
Using Outlet and Inlet Boundary Conditions | tylerplowright | CFX | 8 | January 28, 2014 17:22 |
How to set pulsating inlet boundary conditions with a very high frequency | Ton | CFX | 10 | March 22, 2012 16:57 |
pressure with velocity inlet boundary conditions | Ashraf Sharara | FLUENT | 1 | August 21, 2008 07:29 |
inlet boundary conditions species transport | richard | FLUENT | 2 | August 20, 2008 07:25 |
