Flow cannot pass through fan/impeller component |
June 1, 2021, 11:46 |
Error: forrtl: severe (157)-Flow cannot pass through fan/impeller component
NGUYEN DUY TONG
Hi everyone, I'm using Flow3D-v12 to simulate the air flow passing well-turbine in Oscillating Water Column.
I'm using fan/impeller component to represent well turbine. Pipe: radius=0.3m, Length=1.1325m fan/impeller object properties: outer radius=0.3, Spin rate=209.44 rad, Accommodation coefficient for rotational velocity Ad=987 1/s, Axial velocity coefficientBd=0, number of blades =8, thickness=0.13125m. Fan located at x=0.49m from inlet. As we know, fan/impeller component is treated as phantom component. However, The result shows the flow cannot pass through this object in my simulation and there is an error: forrtl: severe (157): Program Exception - access violation Could you please give me advice about this problem? Thank you Last edited by Thomas Nguyen; June 2, 2021 at 12:23. Reason: addtional information |
Error: Update failed for the setup component in Fluid Flow CFX | nudi1001 | CFX | 4 | January 17, 2023 03:01 |
Interaction between open channel flow and porous flow | narendrapatel111 | ANSYS | 0 | June 8, 2020 11:42 |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
