Home > Forums > Software User Forums > FLOW-3D
Question about bridge scour
Old   February 14, 2022, 01:12
Default Question about bridge scour
Kwok Chun Long
cyruskwok is on a distinguished road
Hello everyone, I am a beginner in flow 3d, I am doing bridge scour.
I want to ask:
1. How can I find the maximum scour depth around the pier from the flow 3d?
2. How to create scour depth against time graph?
3. How to create a top view with contour to show the scour depth?
Your kind help and advice are most appreciated.
This is how my model look like
cyruskwok is offline   Reply With Quote
Old   February 16, 2022, 08:58
UK
redlemon44 is on a distinguished road
>Create probes and monitor the flow depth/elevation or maximum depth. Ensure hydraulic data is enabled in the outputs
>In POST look at the max depth location and create a line graph associated with a line for plotting. It will be for that point.
>You can add contour levels as marked annotations or change the colour bands (colour by flow depth or elevation)
redlemon44 is offline   Reply With Quote
Old   February 16, 2022, 16:19
Kwok Chun Long
Thank you for replying
So basically I should create a history probes near the pier like the picture 1 ? If yes, how should i know which point will be the maximum scour ?
After that, how should i monitor the flow depth/elevation or maximum depth, i can plot flow depth, maximum flow depth and free surface elevation separately as showing in the picture 2 and 3. But the value is not what i expected.
How to improve the lateral propagation of scour hole (3D) sycst911 FLOW-3D 2 April 29, 2014 22:07
Scour around vertical cylinder pyxbird FLOW-3D 5 December 25, 2013 02:28
Ivy Bridge - Haswell - Sandy Bridge russh Hardware 29 August 28, 2013 08:01
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
