January 23, 2024, 21:59 |
Add a fluid region with STL file
Zhaoqi Zheng
Rep Power: 2 |
I want to add a fluid region with STL file. In initial->Fluid Regions->Add a fluid region. Then choose "Use functions coefficients for" "STL Geometry". Then click "change" to choose my STL file. But when I run the preprocess simulation, Something error happened. The error message is "Abnormal exit from preprocessor" and
"processing fluid initialization regions processing cad data for fluid region 1 " How can I solve this problem. |
January 24, 2024, 06:49 |
Sehroosh
Rep Power: 7 |
Run the model with coarse mesh and this issue will be gone.
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
