Home > Forums > Software User Forums > FLOW-3D
FSI-Fluid Structure Interaction
Old   October 2, 2008, 06:02
Default FSI-Fluid Structure Interaction
MAB
I would like to ask for comments about Fluid Structure Interaction in Flow-3D. I need to model the motion of a device which is being induced by fluid around it. I read about GMO Model of Flow-3D.
Old   October 2, 2008, 09:12
Default Re: FSI-Fluid Structure Interaction
Michael Barkhudarov
The GMO is a rigid body, no deformations. Does it sounds like it will be suitable? What kind of device are you modeling
Old   October 2, 2008, 09:44
MAB
yes I am not modelling deformation. I only need pressure and velocities in the fluid while the body moves in response to the fluid motion.
Old   October 3, 2008, 10:27
Stefano
Then the GMO model is perfect! you can have also more than one moving body in your domain, and FLOW-3D solves the 6dof free dynamics of all your bodies, coupling it with the fluid.
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 09:30
Fluid Structure Interaction fw407 OpenFOAM Running, Solving & CFD 9 February 14, 2013 17:25
Fluid Structure Interaction and OpenFOAM capabilities paka OpenFOAM Running, Solving & CFD 1 June 6, 2007 13:56
Optimization or fluid structure interaction Steve_NTUA Main CFD Forum 9 August 29, 2006 03:40
Fluid & Structure Interaction... nesusa FLUENT 1 March 31, 2002 21:30
