Home > Forums > Software User Forums > FLOW-3D
Mesh Blocks
Old   March 20, 2009, 23:42
Default Mesh Blocks
Ali Etesam
a.etesam is on a distinguished road
Hi
In my project i used 2 mesh blocks but in preprocess i saw a warning: open area mismatch at inter-block boundaries of all blocks
as % of total open area at these mesh boundaries = 6.05866E-01
What does it mean? and in final I can just see 1 mesh block!!!!
What should to do? any body can help me? Thanks
a.etesam is offline   Reply With Quote
Old   March 21, 2009, 21:01
H.C
H.C is on a distinguished road
The preprocessor will first try to locate the boundaries where the two adjacent mesh blocks connect, calculate the open areas in each mesh block at that boundary and compare the values. If there is different between the two values, a non-zero area difference will be printed out. The printout value is equal to the area difference divided by the maximum calculated area at the inter-block boundaries.
When there is a mismatch, numerical interpolation would be performed at that boundary to convey the data between the two mesh blocks. To reduce the area difference, users should always introduce fixed points between the two adjacent mesh blocks, so that the grid lines would be aligned at the inter-block boundaries. Please keep the cell size ratio between the mesh blocks below 2, and avoid having the inter-block boundaries at the locations where rapid changes take place.
To display both mesh blocks when postprocessing, you need to click the Mesh Block button at the bottom right corner under the Analyze tab and choose the mesh block(s) you want to view.
H.C is offline   Reply With Quote
Old   March 22, 2009, 00:00
Default Mesh Blocks
Ali Etesam
Hi
With your help Dear H.C now i know that what should i do. thank you very much for your care
Old   March 31, 2009, 20:11
panda is on a distinguished road
It seems this warning message will not prevent you from running the simulation
panda is offline   Reply With Quote
Old   April 1, 2009, 05:21
Ali Etesam
Hi Panda
Thanks for your care buddy
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 16:29
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
