April 23, 2010, 10:02 |
Micro-porosity
Johannes Köpf
Hi All,
I have a solidification simulation with dynamic shrinkage model and microporosity model activated. Shrinkage seems to be ok, but the calculated Microporosity is about 1.E-10. Has someone experience with this combination? Johannes |
May 5, 2010, 00:03 |
michael barkhudarov
Rep Power: 18 |
what version of FLOW-3D are you running? there was a problem like that, I think, in version 9.3, but has been fixed since then.
May 6, 2010, 06:41 |
Johannes Köpf
I'm using version 9.4.1, running on linux 64bit. |
May 28, 2010, 04:28 |
Johannes Köpf
We have verfied the microporosity issue now with different setups. It's now clear that the micro- porosity is only calculated correctly (in combination with the solving of the momentum equations) when shrinkage is deactivated. That's not good, because we would need dynamic shrinkage AND micro- porosity...
December 11, 2013, 09:00 |
lenkenwong
Rep Power: 12 |
Hi Johannes,
I am Ken, studying in germany. I am currently writing my bachelor thesis with flow 3D 9.4.1 as well. I am simulating solidification process. But I have some problems with the display. It doesn't show shrinkage on display and the temperature variation is illogical and the pressure variation doesn't change at all. May I know what settings did you make for this solidification simulation? I do not know where the problem is and i am using copper as my mould and pure iron as my fluid 1. Thanks a lot first for ur attention and time. best regards Ken |
Porosity field in Fluent | wojciech | FLUENT | 1 | September 20, 2010 11:19 |
UDF for porosity | cfd-novice | FLUENT | 2 | August 20, 2009 03:19 |
Volume porosity as function of temperature | Georg | CFX | 0 | October 15, 2008 05:06 |
UDF for porosity | Giacomo | FLUENT | 3 | July 23, 2007 09:23 |
porous media with variable porosity | Kevin A. | FLUENT | 3 | December 24, 2006 10:56 |
