Home > Forums > Software User Forums > FLOW-3D
Warning: surface area for component 1 is zero
Old   June 14, 2010, 07:10
Default Warning: surface area for component 1 is zero
Luchezar Georgiev
luchezar is on a distinguished road
Hello!
I'm a newbie in Flow-3D and CFD in general. I'm trying to simulate a compressible supersonic air flow around a solid 3-D [almost] axisymmetric body. Despite that the Materialise Magics shows a non-zero surface area of the mesh (the STL-file), the Flow-3D preprocessor issues the warning "surface area for component 1 is zero". I tried this again with a simpler mesh but the result is the same. Perhaps that's why the simulation ends in just a couple of seconds with a zero result (nothing seen in the image but the coordinate system and a colour palette). I've assigned a material for the body but had I forgotten to assign a physical property for the surface so that Flow-3D considers it real?
I'll be very grateful if experienced users can help me get the desired image of the oblique shock wave cone. The input and mesh files are at 4dos.hit.bg/flow-3d.zip
Thank you very much for your help!
luchezar is offline   Reply With Quote
Old   June 20, 2010, 19:19
michael barkhudarov
MuxaB is on a distinguished road
Originally Posted by luchezar View Post
Hello!
As you already probably figured out, the surface area of a component is not a given property but is computed automatically by the preprocessor and output as a diagnostic. A zero surface area usually means that the component is not properly resolved or placed in the mesh. For example, it could be outside the computational domain, or the domain is too small (which could be the case when the units in the STL data and mesh data are different).
One way to double check all that is to look at it in the GUI's Meshing&Geometry window.
MuxaB is offline   Reply With Quote
[swak4Foam] installing funkySetFields prapanj OpenFOAM Community Contributions 65 October 8, 2015 17:46
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
Gentoo Compilation woes on AMD64 with fluentMeshToFoamL connclark OpenFOAM Installation 8 February 29, 2008 14:18
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
