Home > Forums > Software User Forums > FLOW-3D
Question about "Domain removing component"
Old   December 2, 2010, 06:13
Default Question about "Domain removing component"
Yang Yue
therockyy is on a distinguished road
Dear all,
If I use a solid component containing a hole with specific geometry to create a mould and use a mesh block containing the mould, are the meshes outside the hole but in the solid component activated in simulation? What's the difference between this kind of cells and the cells in the domain removing component?
I feel the mesh in the wall (solid component) is still activated since it can be used to calculate the temperature gradient and it also can be viewed. But the mesh in the domain removing component seems be removed and only leave a void there.
So, if I run a simulation on fill a mould and I only care about the flow (no temperature,etc.), do I need to use domain removing component to remove the wall between the mould cavity?
Thanks,
Yang
therockyy is offline   Reply With Quote
Old   December 22, 2010, 10:58
Stefano
stefmascio is on a distinguished road
dear Yang,
the cells inside the mould will be deactivated by a solid only if you don't use the "Full Energy Equation" calculation (IHTC=2), otherwise all of them will be active to solve the heat conduction inside the mould.
With 9.4 version (I don't remeber 9.3) you can also set the "Thermal penetration depth" property for your component: that creates an offset of your hole and keeps active only the cells inside the offset, while deactivating all the rest (even with IHTC=2). This is usually very helpfull to reduce the active cell and keep the full energy equation on!
stefmascio is offline   Reply With Quote
question about uds tanven FLUENT 2 July 5, 2015 11:22
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 20:31
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
