Selection of Viscosity for the Solid Phase in the Euler-Euler Method |
June 29, 2013, 06:36 |
Selection of Density for the Granular Phase in the Euler-Euler Method
Rep Power: 12 |
I am using the Euler-Euler method with the objective of simulating the interaction between a particulate and fluid phases.
As the air flows over a packed powder bed an aerosol is created. I am confused as to what density to use: that of bulk powder (720 kg/m^3), as this is the initial state, or that of aerosolised powder (approaching 1.225 kg/m^3)? I do seem to be getting more realistic results by setting the density value significantly lower than that of bulk powder. Last edited by A.L.Verminburger; July 1, 2013 at 04:46. |
euler-euler, viscosity |
Gas solid two phase flow | Liwau | CFX | 4 | March 19, 2004 11:08 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Molecular weight of the solid phase? | imburse | CFX | 3 | May 9, 2002 18:28 |
Unstructured Multigrid Method for Euler equations | Jian Xia | Main CFD Forum | 8 | December 20, 1999 12:31 |
How to calculate density of solid phase | zhou | Main CFD Forum | 0 | December 17, 1999 19:06 |
