Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Have problem with 2 phase porous media
Like Tree1Likes
  • 1 Post By sampathevs
Old   October 2, 2013, 11:16
Question Have problem with 2 phase porous media
Juun
Juun is on a distinguished road
I am doing a simple filter simulation, shown in the pic.
Phase 2 (particle) will stop and accumulate on the left hand side.
Phase 1 (mixture gas) goes through porous media, wall surface reaction happens at the same time on the porous media.
Problems
1. As there is no ‘wall’, I setup volumetric reaction in porous media, Am I doing this correct?
2. How to simulate particle accumulation?
And the last one problem is that the solver runs ok without multiphase (that is only has mixture gas) … but when I switch it to 2 phases, there is error, saying
Divergence detected in AMG solver: phase-1-species-0
Divergence detected in AMG solver: phase-1-species-1
Divergence detected in AMG solver: phase-1-species-2
Divergence detected in AMG solver: phase-1-species-3
Primitive Error at Node 0: floating point exception
Primitive Error at Node 1: floating point exception
Primitive Error at Node 2: floating point exception
Primitive Error at Node 3: floating point exception
The species fractions settings are the same in both cases (with and without multiphase)
Does anyone have any idea about these problems? Many thanks.
Juun is offline   Reply With Quote
Old   October 3, 2013, 00:39
EMAVI V SURYA SAMPATH
sampathevs is on a distinguished road
What is your inlet condition ?
Try increasing the pressure relaxation factor and by decreasing the momentum and volume fraction relaxation factor
Divergence in AMG solver is because of URF's .
Did u define porous zone ?
Regards,
Sampath Emani
rgd likes this.
sampathevs is offline   Reply With Quote
Old   October 3, 2013, 07:44
Juun
Sampath, Thanks
inlet conditions:
velocity inlet for both phases, at 5 m/s (i chose random number, at this stage),
temperature default setting 300k
mass fraction (picked randomly for this stage)
species 0: 0
species 1: 0.1
species 2: 0.3
species 3: 0.5
phase 2 volume fraction 0.1
yes, I defined a porous zone. Do you mean if I have defined porous zone, particle accumulation will automatically appear?
after I reduced some URFs, the error has gone... Thanks
Thanks a lot
Juun
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 07:10
gas through porous media problem jiguozhao CFX 2 February 25, 2011 02:14
Two phase flow through porous media cshah4u ANSYS 0 June 22, 2010 07:05
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
Discrete phase modeling on porous media magnounibo FLUENT 0 April 9, 2009 08:18
