Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
need help for designing slug flow in tube
Prev Previous Post   Next Post Next
Old   April 9, 2014, 17:34
Default need help for designing slug flow in tube
BHG
HARIGANESH
BHG is on a distinguished road
hi everyone
I am trying to design a slug flow in t shaped tube of width 0.5mm suface thicknes of 0.5 mm with two inlet
i used 2d pressure passed , transient , absolute , planar
multiphase model - Volume of fluid
material = air -primary phase , water- secondary phase suface tension 0.07
BC inlet1 - air mass flow inlet of .23 kg/s
inlet 2 - water mass flow inlet of .23 kg/s
wall surface-body = wall adhesion angle of contact is 90
outlet is pressure outlet
solution method is piso
solution initialization is standard , computed from inlet 2 area patched is showed in d below diagram
run calculation time step size is 1e-08
number of time step is 300
i am able to see the flow or but not the slug flow
plz help me
BHG is offline   Reply With Quote
Flow over single tube monoposto FLUENT 0 November 19, 2012 18:47
Flow Through Bend tube of circular c/s applemango FLUENT 0 March 8, 2010 04:52
Flow blowing through a hollow tube pomelo Main CFD Forum 2 October 13, 2009 09:11
Flow around the microscale tube in CFX4.4 hsinluen CFX 2 December 10, 2003 20:53
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
