Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
multiphas flow in double pipes
Like Tree1Likes
  • 1 Post By kh91
Old   April 18, 2014, 14:26
Question multiphas flow in double pipes
azadehkhalili
kh91 is on a distinguished road
Hi
I am trying to model a two phase flow which is consist of vertical double pipe tube. Very hot gas is flowing through the inner pipe and water is the fluid of outer pipe. The water will be vaporized by the heat of the gas and steam bubbles will be appeared. Gas does not have any phase change ; just becomes cooler. I use the mixture model for two phase flow consist of water and steam. Am i right? If not which model is suitable for this case?
The next question is that when i define the gas, in Boundary Condition , fluent activates the 3phases: mixture, phase1 and phase2for gas, while the gas doesn't have any phase change.How can i fix this?
Thanks in advance.
Amir A likes this.
kh91 is offline   Reply With Quote
Old   November 11, 2014, 14:39
G. S.
gerardosrez is on a distinguished road
Hi kh91,
Could you solve your problem??
I am going to perform the same simulation. I am working on the mesh right now, but I will be facing this later
Thanks in advance...
gerardosrez is offline   Reply With Quote
double pipe, mixture model, two phase model
Help with if statement CHARLES OpenFOAM Programming & Development 17 August 22, 2021 03:14
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 01:31
wired error in openfoam conceptone OpenFOAM 4 August 7, 2012 15:45
Inlet Boundary Conditions to model Slug flow in pipes A.Salih FLUENT 6 August 3, 2012 16:31
Annular Flow in Pipes metro OpenFOAM Running, Solving & CFD 0 August 11, 2010 03:34
