Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Drag coefficient flow around hull
Old   May 7, 2014, 13:51
Default Drag coefficient flow around hull
Jordi Bartrons
jordibartrons is on a distinguished road
Hi forumers,
I'm doing a hydrodynamic assesment for a specific ship hull, and the solution seems to be quite accurate, except for the Drag Coefficient. I'm always monitoring it and converges, but the values are of the order of 1x10^3.
I've tried the two ways: Putting nothing in the References Values and putting everything (Wetted Surface Area, velocity, etc.) but without computing from any location.
Also, when I look at the pressure coefficient results on the hull, the values are quite bigger.
Anyone has an explanation?
I'm using VOF model and open channel
Here are a picture of the total resistance report so you can see that the force report are accurate but the coefficient values have no sense.
The other picture is about pressure coefficient on the hull
jordibartrons is offline   Reply With Quote
drag coefficient, fluent, hull, ship flow, vof model
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Drag coefficient of flow past cylinder vs time pedroxramos FLUENT 0 January 14, 2013 12:39
finding drag coefficient in laminar flow ksatpathy STAR-CD 3 January 14, 2010 10:43
drag and lift coefficient Noé Siemens 5 July 13, 2004 10:21
