Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Divergence in Two phase flow.
Old   October 25, 2014, 01:01
Default Divergence in Two phase flow.
black key is on a distinguished road
I am trying to solve a two phase flow with air as the primary phase and inert particles as secondary dispersed phase using Fluent DPM model. The dipersed phase is well below 10% volume fraction required for DPM simulation.
I am not able to converge the solution. I am getting the following error:
temperature limited to 5000 k in #no. of cells. After certain no. of iterations the solutions diverges and blows up. I have used CFL =.1 and DPM urf=.01, but still the solution diverges after initial iterations
Though I have noticed that if I switch off turbulence model ( k-w SST in this case) then the model reaches convergence. Its a steady state simulation.
Please help me regarding convergence !!
black key is offline   Reply With Quote
divergence, dpm fluent, multiphase steady, turbulence
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Two Phase Darcy flow with gravity -> problem Cyp OpenFOAM Programming & Development 0 November 17, 2010 07:58
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 10:20
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 02:20
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 07:59
