December 11, 2014, 10:28 |
[User Defined Scalar in the Eulerian Model
Rafael Cerqueira
Rep Power: 14 |
Hello!
I am very used to the VOF model in Fluent. However, in the past days I decided to simulate a few cases with the Eulerian model. I'm planning to simulate some sort of bubble column reactor with mass transfer with the aid of two User Defined Scalar, one in the continuous phase and other in the dispersed phase. Something in the line of this work "Mass transfer in bubble columns". Unfortunately, I had lots of problems with the user-defined scalars. First, I am not sure how the "mass flow rate" flux function and the "default" unsteady function is modeled when the multiphase eulerian model is activated. The source of this questioning lies in the fact that the scalar is being advected to cell regions where the phase volume fraction (VOF) is zero. To illustrate my problem, I set up one-dimensional case to test a user-defined scalar, located in dispersed phase. In this 1D case i did not added a source term to model the interfacial mass transfer and the spatial discretization used is the first order upwind. The boundary conditions are: west: velocity-inlet - phase-1: u=0.1 m/s; VOF = 0.1; scalar = 1.0 - phase-2: u=0.0 m/s; east: pressure-outlet north: simmetry south: simmetry The results, from a certain time-step are: userDefinedScalar_contour.jpg dispersedPhase_contour.jpg From the two illustrations is possible to see that the UDS scalar field is not being properly advected. The case file and the 1d mesh are here: 1d_test.zip Someone ever encountered this kind of problem? Best Regards, Rafael de Cerqueira |
eulerian, multiphase, uds, user defined scalar |
UDF to modify the value of a user defined scalar | Raja Banerjee | Fluent UDF and Scheme Programming | 5 | March 5, 2019 14:19 |
Implementation: Break-up model of Coulaloglou and Tavlarides | a.weber | OpenFOAM Programming & Development | 7 | September 8, 2014 05:43 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Erosion model and Eulerian Model | leonozx | FLUENT | 0 | April 7, 2011 05:45 |
