Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Outlet BC for subcritical open channel water flow
Old   April 18, 2015, 04:57
Default Outlet BC for subcritical open channel water flow
Ema40 is on a distinguished road
Dear all.
I am simulating an open channel flow (multiphase VOF), in particular a subcritical flow, so I need a specific outlet (or downstream) BC, in particular the water depth. If I do a transient (unsteady) simulation, is it right to impose this downstream BC?
Because, let's you imagine the phisics of the transient time; the channel begins to be filled by water from the inlet; if this water has not still reaches the outlet, how the flow can "understand" the downstream water depth BC that I imposed? Thus, is it right to impose this BC for an unsteady simulation?
Thank you
Ema40 is offline   Reply With Quote
boundary condition, multiphase, open channel flow, subcritical flow, vof
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
reverse flow occur while activating open channel flow boundary? mariam.sara Fluent Multiphase 7 April 26, 2015 07:24
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
pressure outlet (open channel flow) Willem Brantegem FLUENT 2 April 4, 2007 02:40
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 09:39
