June 13, 2015, 09:50 |
Modifying a equation in Wet steam model
Sathya Narayanan
Rep Power: 12 |
Greetings everybody,
I am trying to solve moist air condensation through a nozzle using ANSYS Fluent's WET STEAM model. I have written UDFs to modify the wet steam properties (UDWSPF). In the source term of the 'droplet nucleation' equation, there is a variable 'S' supersaturation which is given by P/Psat. In my case, it becomes Pp/Psat. (i.e) Instead of total vapour pressure, I should use Partial pressure of vapour. Is there a way to modify this built in term ? Or any other alternate suggestions ? |
October 4, 2017, 10:27 |
Rep Power: 8 |
Hello Satty,
Were you able to solve this problem? |
November 12, 2017, 15:46 |
Sathya Narayanan
Rep Power: 12 |
Hi Wadezaza,
I wrote a 2 UDS equations (exact equations used in wet steam model) and integrated them with the mixture model to solve my problem. I did not use the wet steam model. Sathya. |
June 14, 2022, 04:43 |
weijiaLei
Can you share your code with me?
My Email:1253226575@qq.com,thank you very much! |
October 9, 2022, 09:03 |
#5 | |
Arash Moradian
Could you please share the code with me ? I'm sure many of the members would find this code helpful, so ideally you would upload it somewhere, but if you prefer you can send it directly to me at Bronzemoradian@gmail.com or Moradian@bronze.ir |
March 22, 2023, 03:48 |
Rep Power: 3 |
Have you solved your problem? Can you send the code to my email 2778354429@qq.com?thank you
March 22, 2023, 03:49 |
#7 | |
Rep Power: 3 |
March 22, 2023, 03:51 |
#8 | |
Rep Power: 3 |
condensation, moist air, source term, udf, wet steam |
Mixture model Volume fraction equation | me12p1006 | Main CFD Forum | 0 | October 1, 2013 05:37 |
Turbulent frequency equation for compressible kOmegaSST turbulence model | Bojan | OpenFOAM Programming & Development | 1 | September 6, 2013 06:45 |
extracting volume fractions in wet steam model | eromon84 | Fluent UDF and Scheme Programming | 0 | August 17, 2013 13:29 |
