Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Heat pipe wickless-simulation on Fluent-Multiphase
Like Tree5Likes
Old   October 18, 2016, 15:13
Question Heat pipe wickless-simulation on Fluent-Multiphase
Abdelhamid Kassem is on a distinguished road
I'm doing my bachelor project and need to validate my results by simulate the temperature drop across the -heat pipe.
I read a lot about this simulation and end up that i need UDF to simulate the condenser and the evaporator section in a right way.
I don't have have experience in fluent to manage it, and many previous udfs have problem in condensation section.
Could anyone help me with tutorials,idea or solution of this problem?
Please, finds attached the simple heat pipe working principle.
Regards,
A.k
xuansy and anhneim like this.
Abdelhamid Kassem is offline   Reply With Quote
Old   March 8, 2017, 04:50
Thread closed.
I succeeded in simulation of a 2d heat pipe using fluent 17 VOF multiphase model with hooking UDF with the case.
The UDF didn't work on Ansys 16 due to some bug in the program, so you should use ANSYS 15 or 17 instead.
If someone need help in the simulation, write your email and i will send some good resources.
vahidmo72 likes this.
Old   March 15, 2017, 00:37
Default heat pipe simulation
vivek
vmvivek is on a distinguished road
Originally Posted by Abdelhamid Kassem View Post
Thread closed.
Hi, Could you please send me details to vmvivek92@gmail.com
Thank you.
vmvivek is offline   Reply With Quote
Old   March 28, 2017, 09:25
Song
songwukong is on a distinguished road
Thread closed.
Could you please open your UDF publicly? Then more people could benefit from you!
songwukong is offline   Reply With Quote
Old   March 28, 2017, 14:18
Default Udf
Check the attachment
Old   March 29, 2017, 04:39
Song
Thank you!
Old   April 4, 2017, 23:46
Hardik
shahhardikd is on a distinguished road
Could you also send your material to shahhardikd@gmail.com?
Thanks.
shahhardikd is offline   Reply With Quote
Old   April 5, 2017, 00:30
Tamil Nadu
arulmechmb is on a distinguished road
Thread closed.
Please send the details to my mail
(arulkumarkce@gmail.com).
Sent from my SM-J700F using CFD Online Forum mobile app
arulmechmb is offline   Reply With Quote
Old   August 2, 2017, 02:36
Default Need a resources for heat pipe simulation
Pritam Gole
pritam.gole is on a distinguished road
please send the resources to mail id, pritamdgole@gmail.com
Thread closed.
pritam.gole is offline   Reply With Quote
Old   September 25, 2017, 14:37
Alan
Lonerarchon is on a distinguished road
Thread closed.
Greetings, may you please send the resources to antiphilo@gmail.com?
I would greatly appreciate it.
Lonerarchon is offline   Reply With Quote
Old   November 19, 2017, 10:45
  #11
Sherif yehia zakareya
Sherif yehia is on a distinguished road
could u pls send to me code for udf to simulate evaporation and condenstion in heat pipe email
czakareya@yahoo.com
Sherif yehia is offline   Reply With Quote
Old   November 19, 2017, 10:47
  #12
Thread closed.
could u send to me udf for condenstion and evaporation
email czakareya@yahoo.com
Old   March 1, 2018, 02:36
Default bachelor's thesis seeking help
  #13
Stuart Tang
stangxr is on a distinguished road
hi everyone, i'm currently doing my bachelor's thesis on this subject as well. for some reason, my set up always diverges. would anyone be kind to share their case and batch files so i could compare the parameters which i may have set wrongly?
thanks in advance!
stangxr is offline   Reply With Quote
Old   April 12, 2018, 03:53
sajjad ahangar
sajjadahangar is on a distinguished road
Could you please send me the simulation files, UDF and other details to my email. I would greatly appreciate it.
sajjadahangar@gmail.com
sajjadahangar is offline   Reply With Quote
Old   April 12, 2018, 03:57
sajjad ahangar
Old   April 12, 2018, 04:09
I sent the UDF and some useful resources to follow but i can't send you all the case.
Good luck
Old   April 13, 2018, 03:29
陕西
elvislf is on a distinguished road
Could you please send me some useful resources about your case? like UDF, models and so on? I would appreciate it very much. elvislf@qq.com
elvislf is offline   Reply With Quote
Old   May 22, 2018, 07:50
Default Heat pipe-evaporation and condensation UDF
  #18
Find attached the UDF i used for my simulation on Ansys 15 and ansys 17 because, ansys 16 doesnot work with me. It has a bug regarding this UDF.
It takes some time and many trials for simulating the HP. My advice is to start with 2D simple case and then introduce complexity with time. You will need to simulate the boiling tutorial to get some experience about this kind of simulations.
For simulating the condensation, you will need to generate fine wall layers for catching the condensation droplets.
For simulating the Heat pipe you can use these useful tutorials:
1-https://www.researchgate.net/profile...g+Tutorial.pdf
2-https://youtu.be/hPeGvczYHMM
3- https://youtu.be/LQ2y0sIXgio
4 -article: CFD modeling of flow and heat transfer in a thermosyphon
Asghar Alizadehdakhel , Masoud Rahimi , Ammar Abdulaziz Alsairafi
5 -article-2:Three-dimensional CFD simulation of geyser
boiling in a two-phase closed thermosyphon - Hussam Jouhara a,c,*, Bandar Fadhl b,c, Luiz C. Wrobel
If anyone have a question please, write it here so every one can see it and i will reply.
Thanks and good luck
e.smigelskis likes this.
Old   September 20, 2018, 14:09
Default Not able to design the wick less mesh in fluent
  #19
Repudaman Singh Sandhu
Repudaman is on a distinguished road
Please someone upload the mesh file for the heat pipe (2D). I am not able to separate the water and vapor regions and also condenser adibatic and evaporator region.
Repudaman is offline   Reply With Quote
Old   September 29, 2018, 15:36
Tonoy Mondol
Tonoy Mondol is on a distinguished road
hello!
i am doing a simulation of a solar still.it needs an evaporation-condensation phase change model.
my question is in Ansys 18.2 it included evaporation condensation phase change model.is it necessary to use your udf with lee model?
Tonoy Mondol is offline   Reply With Quote
fluent - udf, heatpipe, multiphase, vof
K80 For MultiPhase Flow Simulation in Fluent HyperNova Hardware 1 January 27, 2016 05:53
Multiphase VOF simulation and also Solid Fluid Heat Trasfer gerardosrez Fluent Multiphase 0 November 11, 2014 14:31
Heat pipe simulation nazanin fazeli Fluent Multiphase 0 February 3, 2014 07:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
the simulation of the heat pipe Crystal FLUENT 0 June 21, 2008 10:38
