Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Airlift Modelling
Old   March 3, 2017, 06:06
Default Airlift Modelling
Amit Ray
amitray is on a distinguished road
I am modelling an AirLift where I need to pass compressed air through a pipe to lift water in the vertical pipe as shown in diagram. Water will rise due to density difference. I have not drawn correctly but it’s a U tube type at the bottom. I have modelled everything and have all the required data but I am stuck up at one place that is at the bottom of the vertical Pipe where I have to give some velocity and pressure. As it is transient simulation initially velocity will be zero. But as time progresses velocity and pressure at that place will change and from the tank the liquid will pass through that pipe. I have not modelled the entire domain but just part of that to save computational time. I want to know what boundary condition I can give at that place where water will enter just near the air inlet as shown in the diagram. Kindly help.
Image link Here https://ibb.co/mYMJJv
amitray is offline   Reply With Quote
Old   August 24, 2017, 10:31
Niranjan
chniranjanreddy is on a distinguished road
Hi Amit, I am currently working on this problem. I am also facing the similar problem with the specification of boundary condition at the vertical pipe bottom inlet for water phase. Could you help me if you have made any progress? Thanks-Niranjan
chniranjanreddy is offline   Reply With Quote
airlift, fluent - udf
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM hjasak OpenFOAM Announcements from Other Sources 2 February 13, 2017 04:59
kOmegaSST without turbulence modelling of the flow around geometry CFDnewbie147 OpenFOAM Running, Solving & CFD 7 December 5, 2013 07:29
error message cuteapathy CFX 14 March 20, 2012 06:45
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
