Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Convergence problem on multicyclone gas-liquid separator
Old   December 29, 2017, 10:27
Default Convergence problem on multicyclone gas-liquid separator
Simon Rodriguez
s-rod is on a distinguished road
I've been working on the simulation of a simple vessel with an inlet and two outlets (one on top and the other on bottom). The gas-liquid mixture gets into this vessel and it is split in two streams by a tee. Every stream enters a pipe that acts as a cyclonic separator.
I ran tests in the laboratory and I found that the systems reaches a quasi-steady state when the liquid gets a determined level, and I have no liquid int top outlet nor gas in bottom outlet.
I need to get a cfd model that describes this behavior. I generated a coarse mesh and started to run simulations with the mixture model and the k-omega SST model, steady state solver, the gas being the primary phase. But the model was highly divergent. I healed the geometry in some areas where was not good and the system did not diverge anymore, however the solution I am getting has a lot of gas in the bottom outlet.
This is my first complete multiphase simulation and I've tried a lot of things, for example, i refined the mesh, I changed to K-epsilon, I ran the problem with no liquid at all in the inlet and then tried to incrementally add the liquid in the inlet stream, but I always find that the solution has a lot of gas in the bottom outlet or the system diverges.
My questions for you are:
1. Is there any tips and tricks manual o best practices text in multiphase situations that can help me?
2. What turbulence model should I be using? Do you agree with me on K-omega SST.
3. Most important: Do you know any tricks I can use to improve the solutions I am obtaining?
I append a raw image of the process (please don't be rude on my bad-drawing skills XD)
I really appreciate your help and thank you in advance,
PD: I also tried changing relaxation factors, and eulerian model. Nothing worked.
s-rod is offline   Reply With Quote
Old   December 30, 2017, 01:52
Default turbulence
carlaoc19 is on a distinguished road
Turbulence: RSM
multiphase model: VOF
carlaoc19 is offline   Reply With Quote
cyclone separator
Ideal gas problem Atze CFX 12 March 20, 2014 15:56
error message cuteapathy CFX 14 March 20, 2012 06:45
CM+5 Convergence of the nonstationary problem ILYA87 STAR-CCM+ 0 May 22, 2011 04:35
convergence problem limseokmin FLUENT 3 November 14, 2004 12:43
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
