Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to introduce mixture of air and oil in fluent
Like Tree1Likes
  • 1 Post By maitray
Old   July 14, 2018, 17:14
Default How to introduce mixture of air and oil in fluent
Swaroop
raghuramswaroop is on a distinguished road
I am simulating in fluent to see the coolant effect on tool used in turning operation. I don't know how to introduce mixture of air and oil in the fluent. Can anyone guide me ? It would be of great help.
Thanks in advance.
raghuramswaroop is offline   Reply With Quote
Old   July 15, 2018, 09:21
maitray's Avatar
Maitray sharma
maitray is on a distinguished road
Hey mate, the description is very limited , but this is how you should approach, use eulerian 2 volume of fluid method,specify what are the phases, for eg phase 1 oil and phase 2 = air or vice versa. and in the phase interaction, use any one surface tension model (not sure) , and the challenging part is the solution initialisation , for that i need further info regarding the geometry, i hope it helped.
khaledhmz likes this.
maitray is offline   Reply With Quote
Old   July 15, 2018, 13:13
Swaroop
Thank you very much. Here is the geometry of the part. There is a small surface you can see at the edge. It is the tool tip and it is where I am giving 1090 kelvin as temperature.
I am posing links for the geometry for your better understanding.
https://drive.google.com/open?id=1oA...9vEhWBUjmHkLAu
https://drive.google.com/open?id=1U7...iDsoD6nvzcxlCA
https://drive.google.com/open?id=1qe...qMEfkAzM6O0Nhz
Old   July 15, 2018, 13:33
maitray's Avatar
Maitray sharma
If it is a steady flow, it doesn’t matter at all whatever fluid you are using regarding this simulation since i am assuming you are using fixed temperature boundary, moreover if you are using transient , and if i assume that there is a pipe flow from where the oil is coming ( most common) , then you need euler multiphase volume of fluid method, i hope it helped.
Old   July 15, 2018, 17:56
Swaroop
Ok. Thank you.
Old   August 22, 2018, 09:45
Default ansys fluent multiphase analysis
kiarash
kiarashniroumand is on a distinguished road
hi everyone i am working on a multiphase fluid simulation in fluent . that is pipe that have a saturated vapor with a cooled wall . after simulation with a acceptable residuals and the temperature contours was good but about volume of fraction of each phase there is no good results and all fluid domain have a constant volume fraction . indeed i wanna calculate amount of condensed liquid . is there anyone can help me ? its so necessary for me ...
and also i m sorry of my bad english :|
here is my email : kiarashniroumand@gmail.com
kiarashniroumand is offline   Reply With Quote
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
Implementing the Black Oil Model In Fluent ??? :confused: Abhya FLUENT 2 November 12, 2012 03:59
oil aeration problem wprostaff FLUENT 0 July 19, 2011 15:41
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
multiphase oil air separator tips matt giuli CFX 1 October 6, 2008 22:50
