August 10, 2018, 10:26 |
Multifluid VOF filling simulation
Rep Power: 10 |
Hello!
I wanted to test different VOF modeling options and phase interactions. First I set up a simple 2D geometry with an inlet at lower right hand corner with water volume fraction = 1. Top left hand corner has a pressure outlet with water backflow vof = 0. Primary phase is air initially filling the whole domain. The attached picture shows the water vof at some instance. I expected the water would first fill the U-shaped bottom curve but instead it is flowing as a narrow stream to upright tube. I could not figure out what is driving the water as such a narrow stream. Any ideas what could be wrong? Gravity is set. Reference operating density is that of air. There are no phase interactions set in this case. Model is multi fluid VOF. |
Simple VOF simulation failure | wilandlane | FLUENT | 0 | May 31, 2016 17:02 |
Is it possible to simulate tank filling process in 2D (VOF Model)? | Blue | FLUENT | 0 | November 30, 2013 12:47 |
VOF simulation problem | parisa- | Main CFD Forum | 0 | January 10, 2012 08:33 |
Simulation of filling a pool by Vof | Asghari_M | FLUENT | 8 | February 16, 2010 02:30 |
Simulation of condensation/evaporation using VOF model in Fluent4.5 | Yuwen Zhang | Main CFD Forum | 0 | April 27, 1999 11:48 |
