October 5, 2017, 07:18 |
DPM cone injection Problem
Chris
Rep Power: 8 |
Hi Everyone,
I'm having difficulty simulating a cone injection, settings seen in photo. I cant seem to simulate the spray properly using injection cone, i just get a doughnut. When i use surface injection there's no problem. Can anyone advise? Thanks ATTACH]58826[/ATTACH] |
October 27, 2017, 21:33 |
acharya
Rep Power: 8 |
Hi Chris,
Did you work out how to fix your problem? I need to simulate spray injection and wanted to know if you could suggest any tutorials to learn about multiphase simulations and DPM in fluent. |
October 30, 2017, 09:27 |
Chris
Rep Power: 8 |
Hi p.acharya,
Yeah I solved my problem, I was using the wrong injection type for what I was trying to model, I used the pressure swirl atomizer injection instead. With regard to learning multiphase flow and DPM there are some good tutorials on youtube like this: https://www.youtube.com/watch?v=Y0niw_dUBRU But I would highly recommend signing up to the free multiphase course on learncax. It goes through everything multiphase and even has a couple of exercises. https://www.learncax.com/ |
October 31, 2017, 13:34 |
acharya
Rep Power: 8 |
Thanks for your help ! I'll go through the youtube tutorials. |
January 22, 2019, 05:01 |
#5 | |
Rep Power: 10 |
Here you're handsome, You just change the injection type while you didn't understand Because of what that injection (cone) model don't work. May be it's uncompatible with unsteady simulations? Thank you for your advicing. |
dpm, fluent, injection, multiphase |
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. | Ari | Fluent UDF and Scheme Programming | 4 | May 31, 2016 08:51 |
DPM mass problem | Henrik Ström | FLUENT | 9 | May 20, 2016 11:00 |
Injection of water droplets using DPM | Mona | FLUENT | 6 | March 13, 2013 00:12 |
DPM injection mass flow rate | kingpots | ANSYS | 0 | November 22, 2012 11:12 |
Definition of swirl fraction for hollow cone injection in Fluent | launchpad | FLUENT | 0 | June 30, 2011 03:22 |
