Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Display results from only one phase in a multiphase flow
Old   February 26, 2019, 03:53
Question Display results from only one phase in a multiphase flow
Eline Hansen
Eline is on a distinguished road
Hi
I am modelling a two-phase(air and water) open channel flow. I am studying the turbulence downstream a river with different obstacles, and I would like to insert an isosurface to observe turbulence behind the obstacles. As there is high turbulence in the air, the isosurface is apparing in the air as well. Do you know if there is any way of only displaying one of the phases in workbench results? This would be very helpful for my countors as well, as it is difficult to find a range which gives a good result in both water and air at the same time, and in some cases the values in the water and air are similar, causing the phases to blend togheter, making it difficult to determine where the results of phase two starts.
Regards,
Eline
Eline is offline   Reply With Quote
Old   February 27, 2019, 04:10
annan
annan is on a distinguished road
Dear Eline,
Have you tried defining an iso-clip based on volume fraction of one of the phases ? you can actually define a clip to values of water volume fraction between minimum 0.5 and maximum 1, and you can choose this clip afterwards in the surfaces list to plot your contours on.
Hope this will help.
Good luck,
Regards
Annan
annan is offline   Reply With Quote
Old   February 27, 2019, 05:07
Eline Hansen
Originally Posted by annan View Post
Dear Eline,
Good luck,
Regards
Annan
Thank you very much Annan, this was exacly what i wanted
ansys 19.2, contour, fluent, isosurface, multiphase
Multiphase flow and Phase change due to heat transferevaporation haghajani OpenFOAM Running, Solving & CFD 88 February 11, 2020 08:00
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 08:38
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Multiphase flow in stirred vessel cwl STAR-CCM+ 0 March 15, 2017 11:54
CFX, multiphase flow, boundary condition is only valid for a phase hellowqy CFX 0 October 12, 2016 06:20
