Setting different materials to different inlets. |
May 30, 2019, 15:32 |
Tae Joong Jeong
I am trying to have Fluid_1 and Fluid_2 mix together. The materials' details have been created in Materials section. My channel has 2 inlets and I want to set each Fluid into each respective inlet (ie. Inlet_1 and Inlet_2). I know how to use the VOF models and have been using that but it was having same material into two different inlets. I am not so sure how to explicitly set each fluid to its respective inlets. Please help if you happen to know about this! Thank you in advance. |
Adding material to CFX material library | marlon | CFX | 2 | October 16, 2016 09:33 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
