March 31, 2020, 12:21 |
function calculator interpretation
Rep Power: 6 |
Hello everyone,
i´m running an vof open channel simulation in steady state conditions. My geometry is a channel with a bridge in the flood stream. My setup works fine and the solution animation looks good. Now i am trying to get the water forces/pressures on the bridge surface by using the function calculator. The Problem is that i dont quite understand the meaning, or the difference of some functions. Is there any document in which the calculation basis for the functions are listed ? for example i want to know what exactly the program calculates with the function : areaAve Pressure or areaAve water force and what the mathematical differences between functions like ave or areaAve are (on ave i still define an area but i get diferent results then with areaAve ). Thanks for every help i can get, Regards |
March 31, 2020, 15:17 |
Functions
Area-Weighted Average that the area of the faces on the boundary where a field value is being reported is used as a weighting parameter, e.g., if pressure at outlet is reported and outlet is composed of 1000 mesh faces, then area of each face is multiplied by the pressure on each face and then their sum is divided by the total area. Similarly for other functions. You can refer the following for this
https://www.afs.enea.it/project/nept...th/node411.htm
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
function calculator |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
