June 28, 2020, 21:42 |
DPM poor predictions in Hydrocyclone
Gregori
Rep Power: 7 |
Hello dear all,
I'm working with multiphase simulations in hydrocyclones using Fluent for my Ph.D. thesis. I have some experience with CFD simulations but I'm still learning about multiphase simulations for solid-liquid interaction. For dilute suspensions, I'm trying to use the one-way coupling, and as the equipment is a hydrocyclone I use RSM to model turbulence. First I start the transient solution with water only. When some responses start to stabilize, such as Pressure Drop and outlet mass flow rates, I enable the DPM in the postprocessing step to release particles from injections. I know that the DPM is very sensitive to parameters such as Stochastic Tracking (in turbulent flows) and I tried to use some standard values as there are no detailed procedures for hydrocyclones in literature. However, no matter what I do I always get poor results for particle collection. For example, In my case particles of 5um should be collected with 50% efficiency, and when I track these particles in the solver I get 96%. For smaller particles, this efficiency reduces but is still around 90%. Does anyone here has had the same problem when working with DPM? I know that this is a well-known approach but I still can't solve this issue. I'm using a mesh with 226K elements which is a good size according to the GCI that I calculated. My hydrocyclone is small, with Dc=30mm. I would really appreciate if you could help with this problem guys. I've been trying to search and study with the Ansys Users Guide and some documents that I found on google but I didn't succeed, and this is an important step in my Ph.D. research. |
dpm, hydrocyclone, particle injection, turbulence |
Confused between DPM and multiphase flow | pchoopanya | FLUENT | 0 | June 21, 2019 04:44 |
DPM mass flow | kingpots | FLUENT | 0 | November 29, 2012 22:20 |
Dpm injection mass flow rate | diamondx | FLUENT | 0 | November 22, 2012 13:04 |
DPM injection mass flow rate | kingpots | ANSYS | 0 | November 22, 2012 11:12 |
slow after mesh for enhanced wall treat DPM | joshkemp | FLUENT | 0 | May 1, 2007 17:20 |
