April 7, 2021, 09:55 |
VOF multiphase analysis of a micro-Nozzle
Muhammad Haris
Hello, I am working on two phase (helium and water) volume of fluid analysis of a micro-nozzle, to study the formation of jet and effects of boundary conditions on the jet.
I need help to verify whether the solution models and controls im using are right or wrong because the results im getting are wrong (according to experimental data). General: Pressure based Axi-symmetric Models: Volume of fluid (implicit) Implicit body forces checked Interfacial anti diffusion Checked Boundary conditions: velocity inlets on body Helium and water inlet Outlet = Outflow Solution methods: Pressure velocity coupling = coupled , coupled with volume fraction Solution Controls: flow courant number = 0.25 Vof Courant number = 0.25 Time step size = 10s Number of time steps = 2000 Last edited by harris047; April 7, 2021 at 10:05. Reason: Insufficient information |
April 7, 2021, 19:17 |
Yasser Selima
Rep Power: 19 |
First comment is the time step .. this is too large. To estimate your time step, calculate dt = dx/U where dx is the minimum length scale and U is the maximum velocity in your domain. It is better even to go to less than half this value. Second, Outflow boundary conditions is not recommended in two phase flow. You need to make it Outlet Pressure Third, The results are function of the model as well as the mesh ... you might need to increase the mesh quality and/or refine your mesh |
Multiphase analysis of Humidifier using ANSYS-CFX | Suraj Marale | CFX | 3 | July 28, 2016 11:01 |
Nozzle Analysis | Akbar | FLUENT | 1 | March 4, 2010 11:28 |
axisymmetric nozzle analysis | Marcos | CFX | 3 | October 8, 2008 07:23 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
Analysis of propeller with nozzle | Ammu | FLUENT | 0 | July 1, 2005 08:00 |
