July 27, 2021, 01:38 |
Geometry for CFD-DEM simulation
salma
Hi all,
I'm doing CFD-DEM coupling simulation in a perforated rotary pan, and I did the simulation of particles only using an EDEM solver, the geometry was a perforated pan with four baffles, now I need to implement the coupling process, but still not confident on how to create the geometry in a way to be able to simulate the Airflow through the pan's wall (perforated wall). First, I have tried to use the same EDEM geometry (which is shelled perforated pan opened at the front) and adding an Enclosure to define the inlet and the outlet of the air while crossing the pan's wall, but I couldn't manage to mesh it!! Second, I have created a solid geometry (Not perforated and not shelled) with Enclosure assuming that the air will flow through a porose zone (pan' wall), but I failed to mesh it!! Can anyone advise on how to great the geometry for FLUENT simulation to get airflow through the pan (in & out) while rotating? Here is the geometry... Thank you in advance for your help! Salma Last edited by UmHammody; July 27, 2021 at 16:51. |
[ANSYS Meshing] CATIA Geometry Generation and Meshing | danielsullivan | ANSYS Meshing & Geometry | 0 | April 3, 2017 21:11 |
Best software for centrifugal fan (rotating geometry) simulation | DRoam | Main CFD Forum | 0 | November 18, 2016 16:12 |
import geometry of fliud from abaqus for FSI simulation | mina.m | STAR-CCM+ | 3 | October 31, 2013 11:32 |
[ICEM] Geometry cleaning to use a multidomain simulation | Attesz | ANSYS Meshing & Geometry | 1 | October 20, 2009 09:38 |
Export geometry in workbench from simulation. | kezman | ANSYS Meshing & Geometry | 1 | October 14, 2009 14:06 |
