Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Powder bed fusion
Like Tree1Likes
  • 1 Post By lilas
Old   February 23, 2023, 00:44
Default Powder bed fusion
lilas
lilas is on a distinguished road
Hello All,
I am trying to simulate a powder bed fusion using a moving Gaussian heat source. For a trial simulation, I defined 2 fluids: air and metal. I constructed a block region and put some spherical particles on top of it, and patched them with a volume fraction of 1 for metal indicating that it is the secondary phase. Solidification and melting were turned on and the heat source was applied using a UDF. Although the temperatures are high enough to melt the solid, and the liquid fractions indicate that the solid is melted, the VOF interface remains the same and as a result, the metal does not flow as seen in the literature. Any idea what could go wrong? Surface tension and gravity have been included while the effects of radiation have been excluded for now. Thanks in advance!!
KaWen likes this.
lilas is offline   Reply With Quote
Old   July 21, 2023, 04:01
KaWen
KaWen is on a distinguished road
Originally Posted by lilas View Post
Hello All,
Hello, it seems that the time advantage is late, it is very presumptuous to ask if you solved the problem?
THANKS.
KaWen is offline   Reply With Quote
Laser-based powder bed fusion (LPBF) modeling with FLOW-3D hamedsheikh FLOW-3D 2 December 20, 2022 09:26
[Commercial meshers] FluentMesh3DtoFoam Powder Bed OPFO OpenFOAM Meshing & Mesh Conversion 1 October 15, 2019 03:16
particle generation in powder bed using VOF von karman FLUENT 0 April 1, 2018 06:02
powder accumulation of gassolid flow in packed bed ben CFX 0 July 3, 2006 21:37
high speed gas flow the surface of powder bed? lily CFX 3 November 12, 2005 02:17
